Steve Connally
- Suffolk, Virginia
Wonder where it is now.There is. @Steve Connally was kind enoigh to mail his copy to me prior to my first job, then had me mail it on to another Buzzer.
According to our Treebuzz PM, I sent it to Jarred C. In Wyoming in 2017. Does that help at all?Wonder where it is now.
At least the pick/drop was balanced well. Lol
That would have to depend on experience level and insurance status, not to mention what rates are in your area. Insured climber day rates in this region are $300 on the low side and $500 on the high side.Some solid advice here, thanks all.
We are looking into contract climbers but have an opportunity to sub in with another local company on a massive crane job, both me and my brother on the ground. Not sure what to ask for on a rate. Anybody care to comment on what your rate might be for such a situation? Two guys, no equipment. Sorry if that’s too personal haha.
Great starting point for me. Thanks sir.That would have to depend on experience level and insurance status, not to mention what rates are in your area. Insured climber day rates in this region are $300 on the low side and $500 on the high side.
Where would you say the major time saving comes from when using a lift vs. a climber?Even watching crane work 1 or 2 days will really open your eyes as to what you can do with a crane. Invest in communication headsets, and work with good weight margins. The most challenging part of cane work is estimating weights. The second most challenging is the reverse rigging, and making your cuts to work with the rigging. A good crane operator that knows trees can significantly reduce time on site. Also, we have found that crane work paired with a lift can be done in about half the time of crane work with a climber.
Moving around. If you’re referring to crane work, the guy in the lift can set rigging before the crane gets there, just hook it to the ball and swing down to cut. That time savings alone saves a tremendous amount of time if the crew knows what they’re doing, and can keep the ground crew well buried in brush.Where would you say the major time saving comes from when using a lift vs. a climber?
Some people use 2 climbers, one for setting rigging, one for cutting.
Repels to the ground before the cut. I've done this some.Ive never heard of that...sounds like a hazard. What does the climber do when he gets done rigging? Does he go out with the piece?
We have done that, especially on trees with real long laterals. Rigger sets the slings and bombs out, so the cutter can make the cut, then the rigger jumps back on the ball on the ground.Ive never heard of that...sounds like a hazard. What does the climber do when he gets done rigging? Does he go out with the piece?
That makes sense. The other option is to go up with a number of slings, tie them all, and take the ends to the center. Then the crane operator can just bring his hook to the middle and hook up, and the climber can stay on the trunk. for multiple cuts at a time.We have done that, especially on trees with real long laterals. Rigger sets the slings and bombs out, so the cutter can make the cut, then the rigger jumps back on the ball on the ground.
With the lift, one guy can do both jobs just as fast, or maybe even faster.
We use two sets of slings with the lift, and we do a lot of smaller, single sling picks because it’s often faster and it results in less processing on the ground, which means a more efficient operation altogether.That makes sense. The other option is to go up with a number of slings, tie them all, and take the ends to the center. Then the crane operator can just bring his hook to the middle and hook up, and the climber can stay on the trunk. for multiple cuts at a time.
I've never worked with a second person in the tree.Ive never heard of that...sounds like a hazard. What does the climber do when he gets done rigging? Does he go out with the piece?
