climbingmonkey24
Carpal tunnel level member
- United States
I consider myself a competent climber. I trust in my ability and knowledge. But I still struggle with more anxiety / nervousness in bigger trees.
When I first started climbing in my yard years ago recreationally when I was first learning before I started doing tree care, I used to climb to the tippy tops of all the large trees in my yard and felt fairly comfortable. Somehow, that's changed where I feel less comfortable now then I did when I first started.
I literally sometimes get anxious thinking about climbing to the tops of those same trees. As a matter of fact, a while ago I tried climbing one of those same trees, a leaner that I had climbed to the very top multiple times years ago and sat up there for a while taking in the view, and this time around I was too nervous about something bad happening to be able to make it up even 3/4 of the way. What if the tree breaks in half? What if it can't support my weight because it's a leaner?
I looked at this job today trimming these oaks, and I was hesitant, doubting I could climb the trees, tempted to suggest they find someone else or need someone with a bucket truck or lift, when very clearly I could climb these trees.
For some reason I feel much more comfortable in a smaller-medium sized tree then I do in bigger trees with bigger wood, even though it could be the same job. And there is risk whether you are 20ft off the ground or 90ft. But it's gotten worse to the point that when I am up in a tree, I sometimes start having thoughts of what if the tree fails, what if it tips over, what if something bad happens, and I used to not have this much anxiety when I was first learning to climb.
I would argue I have had much more anxiety in the last year and half to two years what with one thing or another, so I wonder if maybe that is carrying over into my work.
I don't know, just felt like getting this off my chest.
I think maybe I lack confidence / doubt my ability.
