Richard Mumford-yoyoman
Been here a while
- Atlanta GA
Making sure we understand how multicenders work to prevent mistakes, misconfigurations and panic mode.
Likewise. Great to see some familiar faces. I'm lucky to have a rec climbing group but I end up being the defacto expert most of the time, it would be great for me to take a break from that and have more knowledgeable climbers in the group. Hell, I'm lucky to have people who want to go into the woods and climb with me, I'll take it.I got a start on listening. I'm looking forward to the discussion.
Don’t think it’s too long. Great work. You’re establishing a model for what could be happening at small group climber get-togethers more often.I imagine most are like, "right, don't panic and pull down on my Blake's hitch, got it, don't need to listen to an hour of that".
So how does an experienced climber ride a modern device to the ground and blame the metal. (See the paragraph above for that answer)
Hope I don't sound rude but frustrated.
Exactly and we have to know how devices are designed to work so that we can stay out of their way and let them work. Clothing, tools, hands etc. holding down the top "springed" devices or otherwise disabling the "spring" in other devices.if the device is at your arms full extension, you are much more likely to go into panic mode. your natural reaction is to squeeze hard with your arms at full extention. like in a fiotlock prussic. I remember on a blakes hitch which was at a good body thrusting distance from my bridge and I went for a pretty good panic mode slide until I got my sense and let go. when it it is closer to your body, your reaction will be more likely to reach up the rope to grab up and away from the device.
Do you wear gloves? I use those foam nitrile cut out a few fingertips and they work great and find that I don't have to use so much strength to get the same grip on a small diameter line. I think I prefer that to a tooth ascender above.Love this discussion! Thank you Richard for bringing this up. I hadn't put much thought into the components that make up a good multiscender. I am currently really enjoying the Rope Runner Pro and finding that these 3 elements are remarkable, allowing it to function smoothly and consistently. The one well known drawback with the RR is when used with a haul-back (3:1) which interferes with the spring and the controllable friction components. If you let go and release the haul line completely and quickly the Rope Runner can engage the rope, but it takes a leap of faith. I was thinking about this circumstance while watching your video. I use a Footie...soon to be Footie from CI! rather than a haul back configuration in most cases.
Richard, would climbing with a hand ascender above the multiscender be safer on an ascent (as far as the learn to let go)? What are your thoughts as far as having a toothed device above your primary? My hands are getting 'old' and tired so I have been using a hand ascender more and more. Obviously it wouldn't be for every circumstance.
My one worry on training myself to "let go" would be if my multiscender were failing for another reason (and it wouldn't engage) and I SHOULD grip and hold the line to save me from disaster.
Really appreciate your contributions to this industry!
