quick drawing, just showing how i visualize the change in the vector force .. red being simple base tie, blue showing how the angle moves closer to the line of the trunk as it opens up. in the case described the other tree was probably 50 feet away so the angle opened up quite a bit, more than as it looks here.
This is a good illustration of a way to improve how a climber can potentially load a tree. If given this scenario in the real world, I’d take the blue pill.
What I learned when researching for a presentation at expo a few years ago was how much of a role friction plays in the resulting vectors. Essentially, in real lapels application, the vector will rarely follow a geometrical bisect of the incoming and outgoing paths of rope.
I set up several RE Enforcers within the spans of a stationary climbing system. I began with a single redirect over a large union with a 180 rope angle and an Enforcer on the anchor leg and on my climbing side. This allowed me to set a baseline for forces imparted while climbing.and also see how my movement affected the anchor side.
I then added a second redirect and left the anchor side Enforcer in place while moving the second one to the new span of line between the anchor leg and climbing leg.
The data I got was almost mind blowing. I knew friction, degrees of deflection, union circumference, rope type, and several other factors played a role in what the tree experiences…I just had no idea how much. I’m not advocating doing so, but you can almost get to a point with enough redirects that you could base anchor off your lunch bag.
This research really expanded my understanding of the real world vectors, and truly helped me in choosing just how and where to anchor and redirect based on where I need to work in the tree.
Also, David is right in that vector force is slightly redundant, since a vector is the result of a force in a particular direction.
Essay complete. And just as a note, prior to C-19, I spoke with RE about my research and they generously sent me a couple more Enforcers to build a more elaborate system and expand the data. I will likely present again once I make time to run more tests and contact TCIA.
