- Canada
it's a double ended lanyard. id tie in with the other end or attatch my gri gri to a strand. I almost always use a alpine butterfly as a canopy anchor.How would you secure to switch over to positioning once you've ascended? I'd personally go with a prussic out of tenex or ice tail instead, not bulky and pretty cheap. each added connection point adds a point of possible failure IMO
For sure!I'd also add another 1.5" at least to all of the double overhand noose knots you're using. Once you load that lanyard up in real-world use the current short tails will be sucked into the double overhand part of the knot. No matter how hard you set them they compress further in use.
You better be damned sure you get the correct strand. If you need to bail mid ascent, it might be a panic scenario...bees or hornets or whatever. You might think you got it right...or attatch my gri gri to a strand.
