Daniel
Carpal tunnel level member
- Suburban Philadelphia (Wayne)
Guy and I have our differences too. It's not all winks and smiles. My perspective on pruning seems obvious and logical to me. Guy gets it and it's obvious to him too. BECAUSE HES BEEN PAYING ATTENTION TO THE TREES. Gilman doesn't get it which makes about as much sense as Pete Donizelli sideloading a lightning-struck tree with 4 wraps.
For example, when asked about the "1/3rd rule", which states to only prune back to a lateral stem that is one third the diameter of the parent stem, otherwise to remove the entire limb, Guy will come out without hesitation and tell you there is no science to support that rule. It's a myth that has been busted for over thirty years, but the industry hangs on to this complete misinformed teaching. Guy teaches you can cut back to any little sprout after storm damage, or even no sprout, nothing but a node, which is a better option than removing the entire limb.
In this video, it should be obvious to anyone with a bit of sense and experience that Guy's teaching on pruning damaged limbs is correct and we should allow the tree a chance to sprout back from the stubs of broken limbs.
Common sense trumps science. When the science is weak or non-existent, Gilman doesn't have the heart to rely on common sense. When asked about the one-third rule in the below video his reply is gibberish. He says "when in doubt take it out"...WTF does that mean Ed? Does it mean to take the whole limb out? Or does it mean you can make a reduction cut larger than 1/3 the diameter? Why doesn't he just come out and say that rule is nonsense, and we should feel free to remove more of the branch than the 1/3 rule would allow, even if that means taking it back to a stub, rather than removing the entire limb.
To be fair to Ed, he does talk about sprouts as"our friends" and indicate that we should try to save them in this part of the video:
And you want to give Gilman a pass on not being familiar with the European pruning standards? Your analogies are weak. This man is supposed to be the foremost expert on pruning in the US. And he hasn't bothered to even look at the European standards. THAT IS TOTAL BS. You fell for it. Which calls into question your intelligence.
The European standards talk about things like leaving lower limbs on the western side of trees in open areas, to protect the trunk and root zone from overheating in the late afternoon summer sun. That's just common sense to me, but Gilman.. he's got zero on the subject. Guy, on the other hand, is happy to discuss the pros and cons of the US vs European standards.
Maybe he should write an article about it.
