I dont know how this is actually done, but here are my thoughts:Given that the tie in point is able to support the weight of two climbers, is it a feasible option to use the retrieval side of a canopy anchor( alpine butterfly cinch) as an access line to rescue a climber??
Why not climb the tail of the victims line? It'll get you there easiest and safest, then transfer to your own independent system for decent
Should probably add that setting your own independent system from the ground first would be best
Depending on the situation and the rope configuration this can be a realistic option for an access/rescue line. The whole "counter balance" aspect of climbing on the retrieval side can get weird once the rescuer is in the tree, so to avoid complications, I think it could wise for the rescuer to install an independent canopy anchor for the actual rescue work.
Seriously guys, why the resistance to spurs? They are fast, easy, uncomplicated and dependable. Have we become so blinded by our rope skills that this is no longer even considered an option?
Spur climbing is like running in that it goes well in a high adrenaline situation.
