Either a tree spade which looks like you need a 60” maybe a 48” depends on what size they were B&B they look like about 4”-5” diameter treesAny thoughts on streightening up some Callery pears that have been planted too deep and leaning.Soil is heavy clay and trees were delivered balled and burlapped.They were planted sping of 2017.
Terrible treee but hot sellersProbably best to try a different species all together. Callery pears have some unique issues and have caused chaos in many parts of the west coast.
I excavated with my fingers on this one, I am a couple inches below grade and haven’t felt a lateral root yet .Some are planted higher. There are about 25 of them.That lean is totally insignificant and could be mitigated by pruning. Planted too deep in clay soil however is a problem. How deep are you talking about?
Sounds like classic poor stock and planting. Holes could have been dug too deep and then filled prior to planting. The trees could have settled.I excavated with my fingers on this one, I am a couple inches below grade and haven’t felt a lateral root yet .Some are planted higher. There are about 25 of them.
Do you know what cultivar they are. Not all are as problematic as the 'Bradford'. The P. callerana tends to be adaptable to a variety of soil types, but trees in clay should be planted high not low. Best "fix" would be to tree spade up and reset, as has been already suggested. An alternative would be to just scoop out the excess soil from around the trunk creating a tree well. This however may not work if the clay soil prevents drainage of the well.
I think they are Aristocrats, I am trying to post some more picks . I excavated a few more, same thing,top of root flare is about ground level but first lateral roots are 3” or more below grade. A lot of deadwood just above scaffold limbs and epicormic sprouts. They are struggling! Here is one I pruned,most of what I took off was dead.I excavated with my fingers on this one, I am a couple inches below grade and haven’t felt a lateral root yet .Some are planted higher. There are about 25 of them.
3”, this is my Dads property I hope to get down there again right after Christmas, I was just there for the weekend. If ground is not frozen I’ll work on exposing root collars . It really sucks, he paid local landscape co to do planting. I’m no fan of Callery pears but health Aristocrats can be beautiful, I hope this helps! What about soil test kits,are reliable,like the ones from garden centers?Trees take one year pre caliper inch after transplanting before resuming a normal growth rate. What is their caliper?
I would just continue with exposing the root buttress flair as you have shown, maybe a bit farther out. Getting air circulation on that area is the most important. I have seen trees in similar situations do well. Make sure that something else is not complicating their survival.
... What about soil test kits,are reliable,like the ones from garden centers?
Thanks for the education, I did not know growth would be slowed for that long. I’ll send out some soil samples as well.Fields adjacent to trees are leased to a farmer that alternates corn and soybeans every other year. I’m not sure if there are any pesticides or frertilizer applied but I’ll try to find out.Don't waste your time with that stuff. Call a lab in your area, such as Cornell, get instructions from them on taking a soil sample and do that.
Don't fixate on just the soil though. Diagnostics of tree problems requires a broad view. Was the wire cage and burlap removed? Water, either too much or too little, cultural practices in the vicinity, such as field, lawn, and driveway maintenance. Remember also that these trees should be just coming out of their root system redevelopment stage, a time of slowed above ground activity.
Im sureIf I had to bet my life one way or the other, pesticides or fertilizers were applied to the crops.
"Callery pear is tolerant of a wide range of growing conditions, including tough, disturbed urban sites, pollution, dry to heavy clay soils, and sun to part shade" UN-L
Yeah, the base conditions are most likely not a problem for this particular planting, but it doesn't hurt to check anyway. I thought those looked like crop residues on each side, so farming practices need to be looked at, and if the house was built on reclaimed ag land, try to get some history.
