To answer my own thread:
Including the text for future search-ability.
5.4.2 Determining the STIHL M-Tronic™ version
Control unit software version can only be
determined for chain saws and only from
STIHL M-Tronic™ version 2.1.
The STIHL M-Tronic™ version is indicated on the
emissions label after the material no., e.g.:
If there is no such indication on the emissions label,
the STIHL M-Tronic™ version is lower than 2.1.
5.4.3 Resetting control unit to factory default
settings
S Remove saw chain and guide bar or cutting
attachment.
S For chain saws: Remove the chain sprocket
cover.
S Set control lever to the }position.
S Start engine, without depressing the throttle
trigger.
S Allow engine to run for at least 90 seconds in
position }.
S Switch off engine.
The control unit has been reset to the factory default
setting. The engine electronic system has been
adapted to the new solenoid valve.
