dmonn
- Port Washington Wisconsin
Right now I'm mostly felling ash trees (EAB). I climb SRT and cut limbs as I climb, then want to top the tree (usually the top 20 feet or so). Most of the time I don't need to rig the tops.
My tie-in point is usually the top-most division of the main trunk where the size of the trunk still looks safe, but nothing higher-up to tie into. To cut off the top(s), I'd like to be a few feet higher than my TIP for better ergonomics while sawing with a hand saw.
To get the extra few feet, one thought I had was to use a long webbing loop, reach up and girth hitch it a foot or so above my TIP, and use the rest of the loop for a footloop. Maybe create a double footloop for more comfort. I would leave my SRT system intact and maybe slack it a bit, step up with the footloop and lanyard in. Then cut the tops. Does that sound safe, simple, and reasonable? Any better suggestions?
