Went hard on this one. Interested to see how it sprouts.
There is a difference between my trees, a private homeowner, and a public entity in my opinion.It's probably a poor excuse, but I often take less then I would if say, it were my own tree. I don't want to scare the clients.![]()
The site was not allowing new posts for most of Sunday....sorry for the previous post timing wise. I know it is late, I wrote it after post number 8 or 10 or so but my phone said there was some error. I saved it as a draft and it seems I can send again.
I've never really looked at specifying cuts by lengths, but I see the value in that. It would have to change by the circumstances. For example, I just pruned some limbs off my 6" dbh White oak that were 8' long and 1" in diameter... I think there are a few cuts on this one that need to be longer than 8'...but beyond those few, that would be a good plan to focus on 4-8' lengths.I agree that any support system here is likely unnecessary, especially cobra, a short term fix, likely problematic, for a tree likely to live very long. reduce and train sounds good. By species, my first reaction is that the tree is likely more capable than it looks. meaning doing nothing would likely not be too horrible. I think this might mean that reduction cuts could be kept to 2-3 inch max. maybe 1.5 inch even, depending on risks, targets and weights of the tree beyond suspect failure points. That might translate to 8 foot lengths. I think it's important to question, do we need 4" max cuts here? do we need 1" max cuts here? we need specific diameter and or length maximums. keeping in mind we also need diameter range in the application. I used to say 4'-8' lengths removed. now I just say lengths up to 8' removed. minimums are unnecessary, but keep in mind, the closer we get to 0' the finer and more valuable, influential and long lasting the application is. 20-100 additional cuts in the low end of the range (usually made beyond the main reduction cuts) may not change the tree a lot now, but may have a significant influence on its future.
Sent from my SM-G930W8 using Tapatalk
I can address this pretty directly....at least for around here:....
But. this reality also concerns me. I've said it before "why do we use boulevard trees as practice trees?" you see it all the time. if the new guy did it, was the pro around to supervise? was a pro involved at all? you also see good and better pruning on the boulevard just harder for the eye to catch. The point is that these public trees most often get the least frequent and poorest quality of care and attention. They actually deserve the best. They are seen the most, provide the most benefits, shade the pedestrian and the road. They are also the easiest group to care for efficiently on a large scale (in terms of structural pruning, not establishment, which portrays the opposite in many cases)...
good points all around, but storm prep is very important in so many ways........The first after picture should not look 'correct' at all. The improvement should be discrete. (plus it's more important to compare something we never can [except in your head], the pic after a year vs. the pic after a year had it not been pruned) The second after picture should also not look correct, perhaps a noticeable improvement. For a long neglected, wild, or chaotic tree, we should only expect excellent structure after 3-5 structural prunes. Even then, if the tree was mid aged or older to begin with, we can't expect 'correct' structure. But we can definitely expect good or great structure, assuming significant decay wasn't a factor. it's more about improving taper than it is about correcting. Mitigation vs dictation. Subordination vs drop crotching (or reducing even.) and good structure is not a question of how 'correct' it is as much as it is a question of how storm capable it is. prune right, prune light, prune often, not like a boffin. just kidding no poking there are lots of great boffins out there. I like to think I'm one. you're one too. experimenting on trees every day. it's called practice. practice makes perfect not really. it just gets you closer.
all the time. I've found the removal of auxin in the terminal bud stimulates on average 3-5 buds down stream of the reduction cut. I feel that I have directed this future growth by directional pruning on the remainder lateral limb. It works well!In the interest of co-som subordination, do you folks ever make you initial reduction, you "main" cut and then also a small reduction on the branch which have reduced back to? Hope that makes sense...
I do the same. Being able to anticipate and control growth response is a key component in pruning.all the time. I've found the removal of auxin in the terminal bud stimulates on average 3-5 buds down stream of the reduction cut. I feel that I have directed this future growth by directional pruning on the remainder lateral limb. It works well!
