macswan
Been here a while
- Champlain Valley, VT
agree about the michoacan with 10mm cordage. On a bigger rope its necessary imho[/QUOTE]
It is a rope wrench with a round body...
what rope specifically are you trying to use? a 16 strand? the coarse nature of these ropes makes then drag a bit. I have had good luck running 13mm km3 as well as vortex. I like the fatter ropes for removals and smaller trees where I don't have lots of redirects. the wrench should accommodate 13mm with some adjustments to the hitch. you can get away with less twists and wraps with the thicker line and still have a reliable hitch.
Yale xtc fire. some kind of kernmantle with a red and blue cover (12mm i think), and tachyon. Like I said I do use the wrench with three different lines of varying construction and thickness, and I tie different hitches with different cordage on each.
But I really am looking beyond just the hitch. I am aware that they work together, and I completely accept that hitches and rope need to complement one another. The bottom line is that if you put just a wrench with a tether on a skinny line and a fatter line, the wrench on the skinnier line will be easier to pull down.
So feeding myself slack one handed is the area where I'm forced to compromise what I really want in a work positioning tool.
That being said I'd be interested in trying the km3, and I appreciate your input! I'm extremely grateful for my rope wrench and what it lets me do in a tree!
pretty sure yale XTC is a 16 strand. that is what I use for rigging with my wrench because there is so much friction. there is also a lot of stretch in that rope.
If you get a chance, try some Samson Vortex. It should do everything you are looking for....I want to have my cake and eat it too. I want the thing to eat up slack and let me take it out just as fast, while also having a line that's fat, grippy, and easy on the hands (not flat) so I don't have to waste so much time with mechanical advantage when I only kinda need it...
I'm with you on the bigger dia grip thing. I use Arbormaster with the RW, zero issues and a few benefits; Works better with larger diameter hitch cord for smoother all around ops. 16 strand or at least Arbormaster works better in pitchy situations , pitch seems to get pushed into the voids instead of wedging/stopping your hitch like smother jacket ropes.
I also use the CT . I've had 3 total , the straps wore through on 2 of them. The only time I have had an issue with engagement( slipping) is when they get pitch or sap buildup in the area pictured. other than those instances I have never had one slip on any rope.What foot ascender are you using with the Arbormaster? I was finding that the CT quick step didnt always engage properly on that rope.
Interesting. I will have to try again. I remember the spring on my old ascender got weak over time so maybe that was the culprit.I also use the CT . I've had 3 total , the straps wore through on 2 of them. The only time I have had an issue with engagement( slipping) is when they get pitch or sap buildup in the area pictured. other than those instances I have never had one slip on any rope.
