I haven't run a swing cab national but the stand up units (900H) are push away for right. I would believe that maybe when national started building stand up units the main side to stand on placed the swing circle on your left side so pulling the lever towards you brought the swing towards you.
Or maybe there's some completely different complicated reason it's that way.
PCSA standard control configuration on all swing cab cranes require you to push swing lever to move cab toward boom and pull swing control to move cab opposite boom location. works the same weather you have a left or right mounted cab, relative to the boom.Does anyone know why (at least on the nationals) the turn circuit is reversed from swing cab to stand up controls? I.e. push away for right on swings and push away for left on stand up... even joystick setups are like that...just curious.
push the boom away from you, pull the boom toward you.What Mark says!! Move the leaver up and the boom will rotate to whatever side the boom is on, in regards to the operators seat. They taught this is crane school. I was trained on a stand up terex with controls on both sides. Never noticed anything, but when I bought my national with a swing cab, that is the first thing I noticed was the boom rotation was opposite of the terex I was used to running.
