How do you clean sticking carabiners?
Jeff
Marlborough, MA
I use Petzl Am'd Ball Lock 'biners for all my life support needs, and after putting some miles on them, they start sticking. The gate swings shut and the barrel rotates most of the way, but not far enough for the green ball to pop up thru it's hole. Is this a dirt issue, or a lack of lubrication, or both? How do you guys clean them? Dishwasher? Mineral spirits? Or just add dry graphite lube?
What about pine sap? Soap and water doesn't work too well for that...on my hands, at least. That's when I have to break out the rubbing alcohol.
I use this stuff in work for cleaning all our wood cutting tools and also at home for all my metal climbing gear. Works great, it is biodegradable, and its reusable. For biners and such just fill a container with enough stuff to cover the item. Let it sit for about an hour, come back and wipe off.
http://www.amazon.com/CMT-998-001-0...S3TV7H65&dpSrc=sims&dpST=_AC_UL320_SR250,320_
PB takes the place of Go Jo or any thick cleaners. Any veggie oil will cut sticky sap
Boiling biners has been suggested too. The rolling water seems to get inside and seems to float the debris out
Be careful with chemicals & heat.
KNOW your carabiner internal construction !
When I started climbing (2007), I bought a recommended brand that contained an internal plastic component !
1. Some plastics are susceptible to chemical stress cracking. (Expose the plastic to e.g. solvent, it could fracture at a much lower force than expected !)
2. Boiling (212°F) is a very high temp for many plastics.
Hey, Greg! I had no idea they would use a plastic component that is in a place that I assume it is not possible to inspect. For a life support piece of gear, yet.
How did you find out about this, just out of curiosity? Did you cut one open by way of sacrificing it, just to be able to inspect it. It would never have occurred to me that a manufacturer would do something like this.
You would probably be reluctant to say the name of the manufacturer of that item, correct? Do you know if they continue to make their biners in this fashion, or whether they've changed?
In a more positive vein, could you tell me the name of a company or companies that make biners whose quality you really like and that you trust?
Thanks in advance for any answers you choose to provide to my questions, and for your time.
Tim
The carabineer in question used a plastic bushing inside the sleeve for the triple action gate.
Failure could prevent the auto-lock mechanism from working properly.
(It could swell after LOTS of exposure to water, or just gunk accumulation.)
A very small white portion is visible with close inspection.
The climber/salesman that sold it to me, mentioned the potential problem sometime later (1 year ?).
I was told the company stopped using plastic parts.
My point is just know your equipment, or ask the manufacturer.
Thanks for everything in the above post.
My first thought was the Petzl "Ball Lock" family. The ball mechanism is definitely made of plastic.
I will have to look more closely, but I'm not sure you're right about that. It all feels really solid and metallic. They may just make the tip of the button release out of plastic, maybe for comfort's sake. I so far have had no issues with the Petzl ball lock biners. I trust them, so far.
Tim
Tim
Some of the Ball Lock sleeves used to be made of plastic.
They were susceptible to cracking, and need to be inspected. The cracks are easily visible.
I think the design was changed to all metal sleeves.
