I've spent a little time on The Bulldog. The performance will be against what I've come to like with the Unicender.
The Uni is a bit more compact in length and diameter. Not by much and this is NOT a deal breaker
My Uni attaches directly to the rope bridge on my Tree Flex harness. The attachment has a cord in it so the Uni swivels 90 degrees making it fair. The first climb was made using a short screwlink for
The Bulldog to my bridge to keep it short. This worked OK but right away I knew that I needed a swivel link. The next climb was made with a loop made from New England Tech Cord and triple fisher mans. This made the climb smooth. I'm likely to get the mini swivel with the rubber insert...is it DMM?
The attachment to the rope is a little easier using the Uni but, again, no deal breaker
Knowing that the Bulldog captures the rope top and bottom is more secure than the Uni. I'm not worried about the security of the Uni to keep me attached to he rope. But, a few points in. Bulldogs favor
It's going to take more ascents to dial in the neck bungee for the Bulldog. I can see that it will become as smooth as the. Uni. This seems equal for both tools
Feathering the Bulldog is a bit easier to dial in than the Uni. I've never had jerky descents with the Uni but I know some climbers can't figure out how to feather the uni. My guess is that the Bulldog will be more universally easy to smoothly descend or limbwalk
My Uni is a prototype that Morgan Thompson made with a rope capture and roller underneath to aid slack tending. Sinc e his is t commercially available now I'll go with. Bulldog on this.
Since the Bulldog captures the rope all of the time I think that this feature would get enough plus points to wash any of the other criteria
Oh...just thought of a long term Bulldog plus. It's hard to imagine that rope wear will be an issue. What pieces might a rare from the rope rubbing? For sure, not the links
I wish that I was climbing more so that I could get more flight time on the Bulldog. It seems to have solved a lot of the challenges of a multicender in one compact package
Will it be available in pink anodized finish to go with he test of my gear and pink Tachyon?!
