- Chattanooga
Daniel,
Rope stretch is often given by manufacturers of the rope. Some use 300 lbs, 600 lbs, 10% of MBS as the test weight to measure stretch so that makes it difficult to make precise statments about rope stretch. For example, here's PMI's specs for 11mm EzBend - I used that because it's handy for me,
Elongation: 1.2%(300lb), 2.8%(600lb)
You can easily see that the elongation (stretch) at 600lb is a wee bit over double what it is at 300lb.
But, stretch characteristics are not gonna vary so much as to come anywhere close to offsetting a doubled rope factor. So what if it's 10% with one strand and 5% on each strand of a doubled rope? The shock loading on the doubled rope is still nearly twice what it would be for a single strand.
Also, the more rope there is to stretch, the more the shock loading is reduced. If a climber is hanging on a limb in a DdRT setting he is connected by two strands of rope sharing his weight. If he's cinched or choked to the same limb on a single strand of rope with the distance from the limb to the climber the same, friction is pretty much out of the picture and there will be approximately twice the shock loading to the TIP and climber for a given fall distance than with the single strand of rope.
If the DdRT hitch slips, that's a different situation.
A ground tie most assuredly puts more force on the TIP than a DdRT or choked setting would. In reality, friction at the TIP will modify the force to be somewhere between 1.5 to near twice the climber's weight. Further, a ground anchor would tend to bow the tree more near the top because there can be near twice the loading on it. In the case of a fall, the TIP has up to twice the shock loading of the climber plus the weight of the climber.
