Hey everybody,
I have a 1988 c7000 GMC TECO forestry bucket truck. The truck runs and drives it has the 8.2 liter Detroit diesel motor. The motor starts up so easy but is not really the strongest motor I was wondering is there any little modifications I can do I think the air filter is a little limiting because all the air has to come through about a 6-inch hole
But I was able to buy it cash and then willing to put a little bit of work and money into it to get it cutting down trees once again.
Right now I have been using the truck basically as just a chip truck.
Both of the hydraulic Outrigger cylinders are leaking and I am trying to figure out what the best way to repair them would be. I check the hydraulic lines that are running to the Outriggers and they are not leaking at the fittings.
I am not sure the best way to repair the cylinder because the foot on the Outrigger is welded on and there is no opening at the top where I could take the hydraulic cylinder out. Just wondering if anybody has done this repaired before.
The Outrigger is only held on by 3 bolts but the Outrigger cannot lift up because the step and brackets for the bolts will not fit through the hole on the floor and it cannot go down because the ground is in the way.
The other problem that I am having is the bucket does not operate from the controls inside of the bucket it looks like a small line is busted at the previous owner said controlled the emergency shut off when you pull the pistol.
I have a few pictures of the busted line and I'm just trying to confirm that this is what it controls. He said that he believes it is an airline or possibly a very small hydraulic line it is only about 1/16 of an inch inside diameter.
Sent from my SM-G930V using Tapatalk
