- Austin, TX
I have a backup 020T that has been through the wars. I bought it second-hand about 2 years ago from a guy whose employee had been known to chuck saws out of the bucket when he didn't like how they were running (oops, I mean "drop"). Despite all this, it has been a great backup saw--the only problem was going through fuel a little too quick, which I could live with.
But now I have a problem that has me mystified. I'm hoping it might be obvious to some of you who have been around saws longer than I.
The oiler seems very erratic--sometimes not going at all, other times it's a gusher. Again, I could live with that, but the bigger problem is chain tension. It will seem really loose, so I'll tighten it, then it will sieze up like I cranked it down with an impact wrench, then I loosen it slightly, and the next thing I know it's sagging a half-inch again. The bar looks okay--the chain isn't getting wedged into the track as far as I can tell.
I suspected grooves in the sprocket, but it doesn't seem so bad there. I'd almost be willing to just buy a sprocket and try it out, since I could use it as a backup on my newer saw, but I really don't want to spend a lot of time messing with this saw if it belongs on the scrap heap.
Anyone see an obvious fix here I'm missing (or should I go ahead and try a sprocket)? Anyone know what a pawn shop will pay for this saw if they think it works okay? Anyone need an 020T for parts?
TIA,
k
TIA,
k
