RopeShield
Carpal tunnel level member
- Ontario, Canada
How about a rebuild? Any one take their 65 for a rebuild after 15 plus yrs of service?
If no alternator then stator with regulator and rectifier, no?Yes it is. The problem is that the battery is not charging. Don't know how that chipper charges.
I have the Vermeer bc700"xl" it has a clutch similar to a skidoo, it engages when you rev it up.How many hours would you expect with a mechanical clutch?
No, it has an interesting spring mechanism to allow wood to feed.Hydraulic feed wheel lift?
Very interesting. Some AWD cars (including my own) use a similar coupling instead of a mechanical transfer case. I’ve heard it called a “viscous coupling”. My understanding is that the fluid viscosity changes with rotational force, i.e. gets thicker and makes the connection between components.Anyone with experience with fluid coupler on a chippere?
