Rope Runner Problems
That's exactly what it does! I tried this over a year ago, and it (the RR) wants to turn it 60-80*'s from center. Just doesn't work, like it's supposed to. Good idea though!
Dave6390 in WI
I have not had that problem at all, and as far as I can see this method does not add any more friction than any of the other methods I have tried, including advancing the RR with a chest roller and with a couple of different types of eye to eye tethers. When I use the RR, I am using it with a rope walker system to ascend (foot ascender and SAKA), and am using a bungie tether or a lanyard over my shoulder to advance the RR. When I do this the rope is held taut by the lower ascenders, and the RR rides straight up the line with no tendency to go off center. So, yes, I have tried it, and I did not encounter any of the problems that you suggest. I will give it a real workout tomorrow and see if I can make it misbehave.
I run a hydra/rook on an adjustable rope bridge with a DMM Rock "O" to RR or BDB, flat shoulder strap tied into back of TreeMotion Saddle, I attach the Multiscender to a twist Clevis directly to BDB D ring or to a small prussik loop for the RR. I've been building a specific tether for the RR. Here's a pic, should finish it tomorrow morningImageUploadedByTapatalk1449372577.512754.webp
This will attach to an Orca Biner w/ captive wire to Rook.
Dave6390 in WI
It works really great for me, with a SAKA & CT Foot Ascender. So when I raise my arms to pull the rope towards my chest, to stay vertical, the shoulder straps do a perfect job of keeping everything aligned. With virtually no friction on the ascent. I ran a piece of #10AWG solid copper in the RR tender, so I can keep proper spacing on the Orca. I'll occasionally use an Ascentree to keep vertical, but not really necessary for life support!
Dave6390 in WI
I made a bunch of trips up the rope with the loop tethered around the center of the biner and I did not encounter any problems with the RR tracking straight up the rope. It definitely has a bit of friction, but I did not see much difference in friction with the eye & eye tether. But I really like the looks of Mike's solution!
If you have access to a drill press, this spot works amazing.
Hey Mike, I found your old post by accident. Also the one where you mention using a #40 drill to make the hole on the friction plate.
Anyway, are you still using a Rope Runner with the above mentioned tending point?
I've been using mine for several years with the Singing Tree Quickie to provide the tending point but I like your idea and want to give a go.
Steve
Steve
Yup still using the same tending point, no problems and very smooth - gotta make sure you drill perfect on first shot
Thanks Mike. I figured it needed to be pretty accurate especially since the friction plate on my Rope Runner also has a nice rope groove.
Took it to my local machinist this morning...just in the nick of time as he is finally retiring–at 75–and some of his shop equipment had already be removed but not the old Herbert drill press. He used a 2.5mm drill (a fraction larger than #40) to suit some 2.2mm New England Dynaglide throwline. I've just made a simple loop to start with but may put on some heat shrink if it interferes with the beak.
Picture below with both tending points ready for action so can make some in tree comparisons.
Steve
Surprised the runner held on 11.2 wide open! Id like to try some Cougar one day.
Keep those bollards and make some art put of em
If I use a new piece of 11.2mm it does slip in the RR. The trick is to use the new rope with a Rope Wrench and prusik for a while to help fluff it up.
Art work or I could use them as expanders in my ear lobes...no thanks
