Ekka sent me his carb from his 200 that was causing him a lot of problems.After a tear down and under a magnifing glass I found a crack in the diaphragm chamber,on the fuel side.
I have never seen this happen before.I have not one clue what would cause this to happen.The carb appears to be a variation of a Zama C1Q,as far as I can tell.
If I have my facts correct,the saw started,idled etc,just fine.When it got under power,it leaned and died.Starting required a lot of choke.
If my analyisis is right,the saw would draw enough fuel for an idle condition.Under power,how ever,it would draw air,instead of fuel,because of the little bitty crack that went into the venturi by way of the internal chambers.
Well,I got lucky and found the problem.When you think you have seen it all,trust me,you haven't.
