House built around elm removal
The overhang ... was designed not to let the summer sun shine into the house ... but let the sun shine in during the winter months when the horizon drops further South.
Hey Norm, doesn't the southern horizon rise in the winter? :)
That knotless lowering system looks like the way to go in a lot of situations. I have never used or seen it used before. Looks like a spliced eye in the lowering line, with a heavy duty biner hooked through it, girth hitch a sling to the piece to be cut, hook the sling to the biner, and cut away. Is that how it is set up?
The Knotless System works Sue-weet! You can clip many small branches into the snap and make one lower. Care needs to be taken to not shock load beyond the systems capabilities.
Anytime a rope is tied onto a limb the knot will end up underneath the limb when it's on the ground. that makes it hard to detach. At least that is my luck :) with the KS the snap is up in the air and the slings can be unclipped and ungirthed most of the time without getting under the limb. Saves LOTS of time and aggrivation too.
..But I do take notice of minute details in the yards of the yanks.
The roofs are different.
That one is flat! How does that work? I even saw like damp and wet spots coz it didn't drain off right?!/forum/images/graemlins/confused.gif
Be a bugger if it was a steep roof though.
That's not a typical house design for northern U.S. climates, I'm sure during the winter there can be problems when snow builds up on the roof, both with weight of wet snow and water working its way into the roof material. The design is "high-end modern" but not practical.
Cool detail about cutting out the fascia board, I was wondering how you were going to get the lower trunk section out without cutting into the house. The answer, cut into the house! Looks like the architect anticipated that the tree would have to be removed eventually and didn't "contain" it with anything structural.
-moss
Hell I kilt a tree and put it in my house.
Great pics Norm, Nothing like a GRCS and a flat roof! Love that knotless system - slick! That obstacle picture was set up well. Nice of the homeowner to let you walk on that roof -- some flat roof owners get real testy about work'in on em good job!
I hope you apologized to the tree :-)
That is so cool. I did something like that smaller scale with a boned out limb from a cottonwood for my cat and birds to play on. Never thought to do something that big indoors, nice!
Plan on tying in to the tree when you finish off the sheetrock?
No longer akimbo. (not really the right word, but it's a cool one to use)
The woods where I hunted her is being developed -- better art in the house than mulch. The Grandkids, nephews, nieces, love it you can climb it to acess the tower room. /forum/images/graemlins/cool.gif
Sorry Norm I'll move this story over to cranes or overflow after ISA
I didn't really have a point. The picture being oriented the way it was (rather, the camera when the picture was taken) caused a bit of mental instability while trying to right it internally to make better (not the best word) sense of it. I merely rotated the image and used the word "akimbo" in the sense of "wildly (in a psychedelic sense) out of position". The rest makes less sense as it goes.
The tree makes a fine addition to the structure. Has the fiberglass insulation been all covered by now? I believe there would be a constant "rain" of miniscule fibers otherwise.
Now I get it . . makes sense.
Yeh the house is 95% done turned out well I think, I'll run a thread on my Ironwood in the house sometime when my life slows down . . . I know I'll try a zip file!
