I was taught how to do crane jobs from a man who had done many hundreds safely.
For the vast majority of cuts, we do not attempt to 'balance' a limb. Tie it high, so it is butt heavy. Came back and make a notch on top, notching towards the crane's line of lift. Make your back (under)cut an inch out from your notch, leaving a little hingewood along with the little 'step' so the butt will not drop and swing wildly. PUT YOUR SAW AWAY AND MOVE AWAY TO A SAFE POSITION. Then and ONLY then, you give the crane operator the signal to lift. He lifts the limb and it breaks off as it stands up, with virtually no impact to the crane and no chance of hitting the climber.
I have worked with crane operators who started snatching on a limb while I was still cutting, and I damn near came out of the tree to wring his neck!
I had to make it perfectly clear that he was NOT to snatch ANYTHING while I was close enough for him to hurt or kill me. I am not into big wild swings with thousand pound chunks of wood.
Anyway, I learned from a very good climber and feel very safe with the method described.
