The RG85 and the RG90 use the same Duradisk, best I can tell. Why did he take it off? Any idea of what he wants for it and where it's located? (Guessing Ohio)
The old ratio wasn't 2:1, but there was an underdrive between the top and bottom sproket. Do you know the difference in the displacement of the motors? Equal wear would be cool, but it's not easily doable on the older machines. When you say higher torque it sounds like they (the new machines) have a larger displament pump, making the MA there instead of with the belt and pulleys. Interestingly our smaller sprokets wears SLOWER than the large sprockets.
We got 2k hours out of our old wheel, and it had life to spare.
With remotes it would offer better visability, and making a shield for those jobs where you need excellent viz. and want protection wouldn't be hard. There's also nothing to say you couldn't run the remote from behind the machine's
"normal" shield, although I would probably remove it.
On the majority of jobs here, you don't need that kind of vizability on the average stump, and when you did, still can have it.
I'll PM you his number, then you can sort out details. I know it wasnt exactly 2:1. Displacement I'm not sure of, I'm just looking at engine torque specs. That is odd I've alway replaced the smaller sproket first, as it would spin more.
