You dont need to worry about high mod textiles in that scenario. Since in a normal rigging situation the rope runs up from the lowering device (LD), to the block (BL)and back to the load (LO), there is plenty of rope to absorb any shock load.
All the test data and hubub about high mods, mainly Dyneema/Spectra products was collected from doing factor 2 drop test on a completely static anchor. It is highly unlikely that anyone has ever had a factor 2 drop in tree rigging.
The point of the research that created this misunderstanding of how high mods break was to show rock climbers that the practice of doing moves while dogging on a quick draw was pretty unsafe. See, when you are lead climbing you have to climb from bolt to bolt, if working a project route, it can become very tiring for both the climber and the belayer. To offset fatigue climbers will connect directly to the wall with a lightweight sling, enter Dyneema. Some belayers, out of laziness will take the climber 'off belay' while they are 'in-direct' or fixed to the wall with the sling. IF during this time you decide to climb up and 'try' the move and you go 2 feet above the bolt, connected with a 24" sling, and fall; well then you die.
Fall factor is a method for determining the multitude of the loads weight that the rigging needs to absorb. If you but catch a log and the knot is 2' above the block then the LD, which is determined by the location of the knot, will fall 4' before being arrested. If the BL is 30' above the LD then there is a total of of 32' of rope out, that 4' fall on 32' of rope is a Factor of 0.125, a far cry from the factor 2 falls that broke the high mods.
There are materials that will endure higher factor falls, or a greater amount of them in succession before failure. However almost any product, nylon/polyester rope, high mods, three strand, steel chokers, etc; will fail when subjected to a factor 2 fall with a LD within the range of the SWL.
Bottom line high mods are tough stuff, and when used properly pose no additional risk than any other industrial textile when used appropriately.
