Did you spill something? What else would you use it for?
Pretty sure its used in water filters. And our fish tank filter has it.
At country clubs, there were some small spills of herbicide on or near golf greens.
From what I understand, it could be useful for dealing with Casoron, where Casoron should not have been. Like a lady who called once, after "fertilizing" her lawn with Casoron by accident. And the neighbors for a favor.
The sod had to be cut and removed, and the activated charcoal applied to the surface soil.
The local turf supply company carries it.
Here is a quote from one article online...
Activated charcoal (or carbon) can reduce herbicide contamination in specific areas (gardens, greenhouses, lawns, etc.) and can also be used as a root dip to protect transplants (tomatoes, peppers, strawberries, ornamentals, etc.) from triazine or substituted urea herbicides. Activated carbon can also be used to “clean up” pesticide spills.
Other herbicides that carbon can deactivate include trifluralin (Treflan), bromacil (Hyvar X), benefin (Balan), bensulide (Betasan and Prefar), DCPA (Dacthal), dichlobenil (Casoron or Norosac), EPTC (Eptam), 2,4-D, terbacil (Sinbar), and chloroacetamide herbicides such as metolachlor or dimethenamid.
Activated carbon, used in a wide range of applications in diverse industries, is made by heating or chemically treating organic matter to create a porous structure. This gives a large surface area within a relatively small volume. Most activated carbon products are purified by acid and water washes to remove impurities and are available in both granular and powdered form. Charcoal for outdoor grills and the like cannot be ground up to achieve the same pore structure characteristics of activated charcoal on a pound-for-pound basis.
