matdand
- Montreal, Qc
Whats up guys. Just bought a used Vermeer 625 at an auction. It was from a rental company so Im going over it to make sure everything is OK. The cutter disc belt seems to be loose, it basicaly hangs freely and makes quite a bit of noise when I disengage it, so I pulled out the manual.
It says that the belt should be 1.005 times larger enganged than disengaged. That seems pretty exact for me. I guess that the belt should be loose enough to not make the pulleys turn when disengaged, but at the same time it shouldn't have any slack in it. Is this correct?
Ill try to post a pic later. Any help is cool...
