I want to start some SRS, with a wrench / hitch setup. Bought an ISC Apex (bottom one in the pic), and also have a borrowed Notch Flow (top). The Notch is brand new, never used. The Apex has only been used for two 1' (not a typo -- about 12 inches / 25 cm) descents, from initial playing around in my low-ceiling basement. So it's basically brand new as well.
I am wondering about the finish on the Apex's adjustable cam, the lower of its two friction points. It's not as smooth as the Apex's bollard / top friction point, nor the Flow's bollard and SLIC pin. It doesn't feel very rough, but it definitely does not feel smooth either. You can even see some of the color, or maybe fibers?, from my Blue Moon on the cam.
One of my thoughts is that this should not be so rough, and will cause premature wear on the rope. Another thought is that I see users of mechanical devices talk about metal friction points incurring wear and needing occasional replacement, in which case maybe this relatively rough finish will quickly become shiny smooth and not be a problem.
Have other Apex users seen a similar situation on their wrenches? Any advice as to whether this may be a concern?
I did try asking ISC about this; emailed a query over a week ago and have had zero response. I am trying again but am not optimistic. Being in the U.S. I'd rather avoid the international phone call to them if I can help it.
