I use cano oil.
I've never seen winter blend in person, only heard people talk about it.
Normally, my work temps are above freezing.
I cleaned my bar groove, verified output at the case (not as much as I'm used to seeing, but that is more oil on bigger gas saws which would warm the oil), and then got little spraying off the nose of the bar.
The Echo dcs5000 tank seems slightly loose in the body of the electric saw, so even less heat from the motor to warm the oil than a tank with more contact.
I've not looked closely at my dcs2500t's. They have been acting up some (one for some rough treatment, somehow. I generally have very little equipment breakage as my main employee is very careful (sometimes to cautious).
I don't know if it any of it is a problem battery or cold weather-related.
