ClimberClyde
- Portland, OR
Immediate supervision by experienced professionals is necessary for new climbers - active mentorship.Things we learned today-
This is dangerous work, even for trained professionals, so please do not send an unqualified/untrained person aloft to do this work.
Don’t lose tops over backwards.
Don‘t leave fucking stubs, no matter how good of an idea you think it is.
Rescuing an inverted dead body with a heavy top hanging on their neck is not an easy task.
Did I miss anything?
Aerial rescue is something that should be regularly practiced, with another crew member competent and confident enough to be able to successfully perform the rescue.
A second set of climbing gear should be really available for such an emergency.
A cinched climb line should be installed for emergency egress - or even emergency access from a rescuer.
Have a secondary climb line installed. (Especially for newer climbers?)
Never make cuts with only a flip line.
Install a rope when taking tops as a redundancy to avoid uncontrolled felling.
Don't take tops with winds working against you.
Lots of things to learn from this video. Although had I seen a full video including the top going the wrong way, where we see moments leading up to the incident, I would have posted that. That wasn't something I found though (not on Facebook) so I only saw the version I posted. Still something to learn IMHO. I understand where Steve is coming from - the way it's being shared on FB/wherever else for family/friends to see is rather gross. I don't feel that way about it here in this context, but that's my opinion. I respect where Steve is coming from.
I never said I craved respect, I don't know where you got that. In the states police don't get respect lol.The more regulations thing get bandied about a lot.
I’m definitely against it.
Where do you draw the line?
You can change the brakes on your own car which has the potential to kill multiple people if you get it wrong, but not cut a branch off a tree?
As for being taken seriously and not been seen as glorified landscapers, so what? What do I care? I get paid well for my work, that’s enough for me, if you crave respect for your work then become a nurse or policeman.
I think a good place to start would be having ANSI Z133 standards go into effect as OSHA standards for tree work. The fact they are un-enforceable suggestions is a joke that I wish people took seriously. I have zero issue with the idea of being fined at OSHAs rate for not following those rules. They keep us safe and ensure new guys are kept safe as well. OSHA has nothing specific to tree work - they refer to the "recommended" ANSI guidelines. They shouldn't be recommended, they should be law (OSHA standards).
