Zebco Kid
- Ashland, Oregon
Hello All,
My normal tool for climbing both SRS and MRS is the HitchHiker XF.
If I want to traverse to another limb, I will often use the other end of my line. I will make all the necessary throwbag/grappling hook moves to get situated and secured. My tool of choice for the other end of the line is a HitchClimber Pulley and hitch of choice. I will then ease out my XF TIP while easing in my HC setup. It's one of my favorite parts of climbing...traversing my way through the canopy.
So...that leads me to my question. As I'm working with the "other end" of my rope, there is no spliced or sewn eye. I keep reading that it is not recommended to work with a HitchClimber Pulley with a termination knot, as it (the knot) can disrupt the effectiveness of the hitch/prusik.
My thought was that maybe a Figure 8 up the line, and out of the way of the HitchClimber and hitch would be a reasonable solution. I would like to know your thoughts/solutions when a spliced or sewn eye is not available to you, but your available tool is a HitchClimber Pulley?
Thank you.
David
Thank you.
David
