Phil
Carpal tunnel level member
- Oak Lawn, IL
I don't want to spend the money on a snake anchor. I have some 3/8" Tenex Tec and a small rigging thimble so I made a clone. Tight pockets and a short but good in-tree usable length for redirects or a make shift friction saver. Has anybody done break test strengths of pocket/ultra slings when loaded in this configuration? Pocket slings are generally loaded in a choked configuration and this would pull directly against the brummel's so not sure if the breaking strength would be affected in a negative way. It won't have the shock absorbing properties of the snake anchor but this is more proof of concept than trying to make an exact replacement. Thoughts? Mostly concerned about the strength of the configuration.
