Reach
- Atglen, PA
The best thing I have found for scrubbing that stuff off is a Brillo pad. Not a knockoff brand, the Brillo brand works best.My late night snack is in the toaster oven. Nothing fancy, especially compared to what is shown in this thread.
Since I'm single there's no way to do the cook or wash dishes, I do both.
My guess is that someone here has an answer for me on the washup side of cooking.
There are some pans that have the brown layer from cooked on oil. I've tried baking soda/peroxide which is supposed to work as good as industrial paint remover...not.
Is there some concoction that works? One time I had a dab left in the spray on oven cleaner. Not enough to do the oven so I cleaned one pot..sorta. I'd like to find something lower down the Toxic Avenger list too.
The treasure of my kitchen is a waffle iron my folks got as a wedding present in 1947. I still use it too. Original cord with the 'plaid cloth' cover. Every once in a while I spend time with Bar Keepers Friend, green scrubber and tooth brush. Still leaves gunk.
Timer went off...snack time.
I also have good results using the dishwasher, on its strongest setting, with the best quality dishwasher tabs I can buy. All my pots and pans go in the dishwasher, with exception of my cast iron. It just gets a little water and a plastic scraper if necessary, if something is real stuck I’ll put it on the stove with water in it and let it get good and hot and then sit a little while before I scrape it out, then always put it back on the stove to dry before I oil it up while it’s hot.
