- Santa Cruz
I broke the two sewn dog bones I made and the results were interesting. I used 8mm Maxim accessory cord rated at ~2800lbs & Marlow #8 twine rated at 75lbs. Both breaks happened right at the last couple stitches on the standing end side. The cord I used has a 7 strand core so I am guessing the last couple stitches create a weak point where only part of the core is bearing the full weight/tension and/or the stitches basically cut part of the core when under great tension. No load cell, yet, so I can't speak to the actual strength but I had to use my come-a-long in double line config with a pulley to break my samples. The strength of the stitching is very impressive. I am concerned about the weak point at the end of the stitching but I suppose that may be unavoidable, and a braided core might behave differently than the stranded core on my samples.
If anyone else has noticed breakage right at the last 1-3 stitches I would be interested in any thoughts as to why and how it might be prevented or made stronger.
