I see that. Shoot up and over. Pull twice the height of line down. Add throw bag and pull up then lower straight down. Haul up climbing line.With bags on both ends of the line, it's pretty easy to overshoot the whole tree (especially with an air cannon), and then manipulate the line backwards and forwards to eventually isolate a suitable union to climb into. A lot of newbies make the mistake of trying to hit the union directly. Sometimes a longer way home winds up being faster.
I do thankfully have three throw lines and 4-5 bags.Double bagging is the way to go in busy trees. but you need two throwlines, preferably 2 diff colors. 4 bags min. If you do not know this technique learn it fast. It is the bees knees for isolation....Learned it years ago at a comp. it really is the fastest way to isolate in busy ass canopies. Always use loads of weight when isolating to accommodate friction.
Ok no more talk go get it!I do thankfully have three throw lines and 4-5 bags.
That’s not for a rookie/rec climber. Easy for a pro who makes their daily bread on removals.Just get some spikes and a flip line and run up there and get it.
You can have it done in minutes.
Tree will be fine.
More likely than other trees but we've got tons of pines around here that get gaffed by line clearance crews pretty often and they're still alive, also given the time of year for many of us we're getting into a season when beetles are far less active, I wouldn't gaff it but I also wouldn't say it's "almost certainly a death sentence" either.Pine are some of the most susceptible to beetle infestation. Spiking it is most certainly a death sentence.
I have two main cubes, one had a 75' line, one is 250'. 12 oz for the main ends, a heavier bag for the bottom ends.
Aim for the bottom of the upper constraint of your "window", not the bottom.
West coast/East coast-More likely than other trees but we've got tons of pines around here that get gaffed by line clearance crews pretty often and they're still alive,
The top of that obstructing tree is the bottom of your 'window', unless you're target crotch is even higher. The next branch above the target crotch is the top of the 'window'.Aim just above the top of the tree that's in the way?
yes yes yesI have two main cubes, one had a 75' line, one is 250'. 12 oz for the main ends, a heavier bag for the bottom ends.
Pines in general use oozing pitch to clog up bark beetles trying "get in". During the growing season it's effective deterrent. In other months depending on what part of the world you're in a conifer can't mount that defensive strategy as well. But the real point (no pun intended) is there's no need to gaff this loblolly.West coast/East coast-
