eyehearttrees
Not a new Member
- Tampa-Area
tl;dr--- If you have a ~14' tall, 4' wide DBH oak trunk (just trunk) to fell, but a very tight felling-zone, wouldn't it be OK to simply take the top 4' section off, noodle/cut it in half lengthwise and lay the two halves on the sod cut-faces down and perpendicular-to the trunk you're about to slam onto them....then simply butt-hitch the trunk's base so that, when it slams its 'crash pad', that it doesn't bounce too far away! Can draw an illustration if helpful!!
Cannot say I've seen others doing the "butt-tie the trunk's bottom", I've done this in several circumstances where it was important that the trunk stayed-put once landed, am planning to do that here (literally just roping as-if you were butt-hitching the piece, only you've gotta be real precise in how much slack is on the line...and obviously that the cordage is appropriately robust!)
Crash pads.... I know that it's generally not advised to make them from the very tree you're cutting, but in this case I'm not protecting asphalt/concrete I'm merely protecting the sod.... My thinking was:
"Trunk is about 15' tall right now and 4' DBH, I have to take about 3-5' off the top so I can fell the remaining portion so I'll just use that cut-top of the trunk as my crash-padding" (obviously I'd halve the wood, and put the wide sides facing down on the sod, laid perpendicular to the big 10' trunk that will be slamming-into them)
Thanks for any insight, am really trying to get this trunk to land - and stay - in a very tight space, am fine with it bouncing since it'll be butt-hitched (and'll have a pull- / tag- line connected to its top, not that I'm fighting lean but just because I like doing that whenever possible, have some pressure in my fall-direction!)
PS- If it matters, my plan was to make a 'open face'/humbodt notch, not a flat-bottomed notch like usual, to prevent excessive 'hop' off the stump...also planning to make the cut around 3' off-ground, both for comfort and to make the top of the trunk land a bit closer to the stump (trunk cannot go too-far forward, or to either side...and don't wanna destroy the sodding if I can get-away with it!)
