Reach
- Atglen, PA
You’re welcome! 11k sounds reasonable, I’ve never worked with a 50 ton. We use a 40 and 45 regularly which both pull about 10k, and rarely a 70 if we need bigger, which pulls 13,500 I believe. We used a 55 a couple years ago, but don’t really like that company, and I don’t remember what it could pull.Took me longer to type the question than for you to answer it. Thanks for the sling info.
I believe he mentioned 11,000lbs on the cable. The first piece came off a little heavier than he predicted, which likely led him to be conservative. We were also trying to keep the pieces a consistent size at the end while keeping the 10' stump. Ended up with about a 3' length to get the final height that weighed 3,000lbs. The previous two picks were 5000 and 5500
Sizing the pieces like that makes good sense, and that big heavy piece in the middle would mix things up too for sure.
