deevo
Been here a while
- Horseshoe Valley, Ontario, Canada
Wtf
Wow that's terrible. Well wishes to the operator and family all involvedFriend sent me this from face crack. Pretty scary
The break looks very clean and even. Maybe a weld failed? Kind of a weird spot for a weld though.Ok here is what I found out.
It was sudden failure and did not come apart the square tube just broke!
I am still trying to get some more info on it. The machine is newer low hour and not abused in any way. If I hear more I'll post it.
This is crazy. I hope for a good recovery. We had the frame on a larger Morbark M18R chipper break just like this. The frame is tube steel and it broke very clean, and not near a seam or weld. The chipper has a lot more vibration during use than a lift, and also going over train tracks and pot holes may have weekend our machine. Whatever the reason, the material should be able to handle all of that. The frame was broken on both sides.No weld seam as far as I know.
That's crazy how it tears so straight. I almost wouldn't believe that's possible, other than the 3 examples in this post. I'm glad you noticed that before a complete failure going down the road.This is crazy. I hope for a good recovery. We had the frame on a larger Morbark M18R chipper break just like this. The frame is tube steel and it broke very clean, and not near a seam or weld. The chipper has a lot more vibration during use than a lift, and also going over train tracks and pot holes may have weekend our machine. Whatever the reason, the material should be able to handle all of that. The frame was broken on both sides.
Any idea on time lapse between two fails?Just seen this on fb
Apparently it has happened at least twice.
There is a much beefier center support on these machines that the pintle is actually bolted to which is why the chipper is still in a normal orientation. We have 5 of these chippers in our fleet. Inspection of the others led to discovery of cracks on at least one other unit.That's crazy how it tears so straight. I almost wouldn't believe that's possible, other than the 3 examples in this post. I'm glad you noticed that before a complete failure going down the road.
Steel often seems to break/tear in a straight line like that. It seems odd, but steel does actually have somewhat of a “grain” due at least in part to the manufacturing process. If I recall correctly, hot rolled/formed steel has more of a grain than cold rolled/formed, but I may have that backwards. I do know for certain though that cold rolled steel is stronger than hot rolled.That's crazy how it tears so straight. I almost wouldn't believe that's possible, other than the 3 examples in this post. I'm glad you noticed that before a complete failure going down the road.
