im not gonna get in a car accident during normal driving eitherI'm not gonna drop my saw in normal use
“ never dropped a saw”? I’ve dropped out of climbs and buckets.Was having a discussion with a co-worker about the practicality of having a leash on your saw while aloft. I used one for quite a while, but stopped a couple of years ago and haven't looked back. I find it is one less thing to get tangled and allows for more freedom of movement while cutting. I get the safety side of things, but I have never dropped a saw, and I pointed out that most guys in a bucket don't use one. Thoughts?
fair enoughI've never been in an accident, at fault or otherwise because I pay attention and am a defensive driver. And I've done a hell of a lot of fucking around in a car, to say I only drive "normal" would be false, I drive an AWD sports car (STi), I drive far from what most people would consider normal on the reg, especially with this weather. Yet I've never once had a fuck up in my almost 20 years of driving (speeding tickets are another story lol).
Sure anything could happen but if you pay attention, exercise caution and plan your cuts I can confidently state I won't drop my saw.
Do you consider it wrong to proclaim you won't cut yourself with your saw either? I sure as hell don't
A non breakaway lanyard is way worse if a chunk yanks it, and consequently, yanks your body, than losing a saw. IMO, not IME.Homemade saw lanyard.
Didn’t much like this Kong biner after noticing it seems to be painted rather than anodized, and it fits all my saw handles.
I'm using a homemade lanyard made of 1" tubular webbing. No bungee, no tear away feature. Even though it doesn't have a lot of stitching, I'd hate to find out its breaking strength the hard way. Anyhow, I figured the ring on my saw (194T) was the weakest link. My lanyard only attaches to the ring (not the handle.) Anyone have an idea of the rating of the ring? Or failed a comparable ring?I tape open my saw-hanging biner, making a big hook.
I don't like moving around a lot with anyone beneath me
I gaffed out and slid a very short distance, like under a foot, I believe before regaining a spur and stopping.
Jammed up a joint in my spine for a couple weeks. Actually considered a chiropractor visit. Couldn't get it to pop.
Hope you consider a breakaway connection to your saddle.
Exactly how is your lanyard constructed? It appears to have bungee or surgical tubing inside, but the resolution isn't good enough for me to tell how the eyes are finished. Is the elastic action strong enough to keep your saw from bottoming out under normal conditions? I toyed around with some bungee and surgical tubing, but couldn't fit enough inside 1" tubular webbing to do much good. (But I only tried stuff I had on hand.) Ended up making something simple.Homemade saw lanyard.
I do not know what the rating of that ring is, but I know it’s a lot more than what you would expect. I watched a climber (not a very good one, to say the least) get his saw stuck in a log as it went over, and it held in the kerf well enough to bend the bar of the saw 30 degrees, and yank him off the spar. Fortunately his lanyard caught him, but he took a very hard jolt, far more than any breakaway lanyard would ever allow.I'm using a homemade lanyard made of 1" tubular webbing. No bungee, no tear away feature. Even though it doesn't have a lot of stitching, I'd hate to find out its breaking strength the hard way. Anyhow, I figured the ring on my saw (194T) was the weakest link. My lanyard only attaches to the ring (not the handle.) Anyone have an idea of the rating of the ring? Or failed a comparable ring?
Now you've got me considering adding a low strength component. Thanks for sharing the event you witnessed. I do have a question about it, probably because my limited experience isn't giving me the correct picture, so please bear with me. I'm picturing chunking down a spar. As the log falls over, the kerf you're cutting opens up and is no longer a kerf so I'm not picturing how his bar was held in the kerf. Did he have his saw in a cut that was not one of the "felling" cuts? Did the piece fail while cutting the notch? Screwed up snap cut? I'd rather not learn this lesson the hard way.I do not know what the rating of that ring is, but I know it’s a lot more than what you would expect. I watched a climber (not a very good one, to say the least) get his saw stuck in a log as it went over, and it held in the kerf well enough to bend the bar of the saw 30 degrees, and yank him off the spar. Fortunately his lanyard caught him, but he took a very hard jolt, far more than any breakaway lanyard would ever allow.
