- Minneapolis
Okay, so I just became aware of two competing "truths" that I've had bouncing around in my toolbox for climbing and rigging:
1. While rigging / routing SRT basal systems, it is good to load the spine / spar of a tree or limb, since you deflect a lot of force 'vertically' with the strength of the tree. Basically, the principle behind fishing pole rigging. This is why we put the portawrap at the base of our tree, directly below our anchor more or less. In this way we reduce the side loading of the anchor point and the torque in the system. Right??
2. Vector forces - more open angles reduce the force on the anchor point. I just watched a video of Dr. John Ball mentioning that a basal anchor further away horizontally doesn't 'make a huge difference, but is better than straight down because you open up the vector angle. (He also cautions it is riskier / less ideal to do since you inevitably add more things, obstructions, or chances for error this way)
So....I had always thought that you shouldn't be basal anchoring far away from your TIP due to the torque on your tie-in point. What am I missing? #hopeit'snotobvious
