- Gonzales
What is everyone's minimalist lanyard setup? Or the lightest setup you can imagine.
I have not, but would not for a lanyard, as it has very little (like, none) abrasion resistance. We run it for chipper winch cable, and it does not take much to get torn up, even with three feet of chafe sleeve at the end.Has anyone used amsteel?
Do you know of anything that is light like that?I have not, but would not for a lanyard, as it has very little (like, none) abrasion resistance. We run it for chipper winch cable, and it does not take much to get torn up, even with three feet of chafe sleeve at the end.
I do not, personally I would use a normal lanyard, perhaps tri-tech would be lighter than average, and call that good enough. As stated above, the saddle is the big difference. My Petzl Sequoia, for example, is about half the weight of my Weaver Cougar. Huge difference there, versus a few ounces difference in rope weight.Do you know of anything that is light like that?
Yeah I don't plan on using it when I use ddrt but when I use my sticks I need oneDo you need a lanyard - for what you are doing? I mean, no lanyard would save a pound.
If you do need one, chop 12' off that hank of predator and tie a knot.
