- Portland
Hello tree climbing brothers and friends,
I am seeking help in understanding some math according to a recent removal where I wrecked a 1" Stable Braid.
I was called in to finish(block down wood) on a 4' DBH cherry removal. No drop zone between two houses. Rope could not run, and due to stretch on 1" was pre-tensioned on the GRCS and locked off, creating an environment for shock load. 1" ISC block and 1" Tenex Whoopie. I was taking 6' x 2'ish-3' logs, tied up by half hitch to ISC Big Dan on double fisherman's anchor knot(choked).
After a few pieces were rigged out, half of the sheath appeared to be compromised(burst strands) and core was exposed, at approximately where the half hitch on the log was being tied. The distance between block and half hitch was as short as possible considering circumference, directional notch, and enough room to not melt the block sling with a 660 muffler(probably about 1.5'-2').
***I recognize that there are better rigging solutions(double blocking, rigging rings, etc.) for this type of work, but I did not think that it was beyond the scope of acceptable risk to continue with the limited tools at hand and by the time expectation set by the tree boss.***
Log Weight Pro says the logs were no greater than 2,200 lbs and in a typical negative block rigging scenario should not generate more than 20k force. So, how did I compromise the shealth on a rope that has an ABS of nearly twice the potential force at 39K?
