Belay devices: Are they well suited for Tree Climbers?
John@TreeXP
This topic is the source of some heated discussions so I've decided to address this from my own perspective and write the following article which I've posted on my web site at: http://treexp.com/belay-devices-are-they-well-suited-for-tree-climbers/
Belay Devices: Are they well suited for Tree Climbers?
There has been a lot of discussion about using belay devices for tree climbing. Many belay devices are lightweight and perform well for their intended uses. Products like the Trango Cinch and Petzl Grigri have made the leap from being a rock climbing belay tool, using dynamic or more springy rope, to a tree climbing progress capture device used with static or less springy ropes typically used for tree climbing. A belay device can also be used by a tree climber in a number of ways, including as a lanyard adjuster. Some go so far as to claim a device like the Madrock Safeguard (a hybrid belay device) can work as a tree climbing saddle’s rope-bridge adjuster.
My intention is to help educate and draw more attention to the similarities and differences between rock and tree climbing gear. I touch on the topic of non-conforming uses of gear, outside of a manufacturer’s guidelines. I’m not an expert rock or tree climber and my views may be taken with a certain degree of skepticism. However, I do my own research and accept responsibility for my opinions and views.
Tree climbers are resourceful when it comes to making things do what they may not necessarily be intended for or designed to do. For that reason, I will try to clarify things for beginners to better understand the trade offs when using belay devices for tree climbing.
As a rock climber is being belayed, the ground person uses a belay device that connects to the belayer’s climbing harness. Rope passes through the belay device, enabling the belay person to feed and retrieve rope or simply manage slack.
When considering the purpose of the belay device, there are two primary functions being addressed. The device locks onto and engages the rope when shock loaded and it enables the belay person to feed rope out or in through the device. The principle is fairly simple.
When a climber falls, it shock loads the belay device, which then engages or locks onto the rope, enabling the belay person to absorb the shock load of the falling climber and then feed more rope through the device to safely lower a climber back down to the ground. The weight of the falling climber is transferred to and absorbed by the belay person and partially by the dynamic rope absorbing the shock load. A belay person also helps the climber by managing the slack of the rope, by feeding rope in or out through the belay device during the climb.
Tree climbers typically use static ropes, without the same degree of elasticity of dynamic ropes used by rock climbers. A vast assortment of belay devices are currently in use and one of the two that have made a cross-over is the Trango Cinch. It’s no longer in production, but it supported larger diameter ropes used by many tree climbers. The Trango Vergo is the Cinch’s replacement, but 10.7 mm is the largest diameter rope it uses, based on the manufacturer’s guidelines.
The Cinch and GriGri, according to the manufacturer, offers a range of use by allowing a range of rope size diameters to work within the device itself. The GriGri supports ropes sized 8.5 mm to 11mm, and the Cinch 9.4mm to 11mm. Since tree climbers are known for pushing the envelop and by experimenting beyond what a manufacturer recommends, they’ve found that certain devices may work on certain larger static climbing sized ropes with varied levels of efficiency, contrary to the product manufacturer’s instructions and/or guidelines. Some tree climbers are more cavalier and do this solely at their own risk without first contacting the manufacturer to determine whether this is an acceptable risk. One may argue that there’s perhaps a 0.5 mm degree of variance, given the fact that a rope changes between the time it’s brand new and becomes more fully broken in, but using this or any product outside of the product manufacturer’s guidelines, is not recommended.
In the context of being used as a progress capture tool for a climbing lanyard, a belay device may perform well, notwithstanding the fact that, by design, a rope can move or be feed through the device when it isn’t engaged or tension loaded by the pull of the rope. For tree climbers, whether this can cause the rope to creep or slip unintentionally is almost a certainty, because that’s what a belay device is designed to do. Nonetheless if a tree climber is mindful of the device’s characteristics and maintains a consistent load on the device when in use, it becomes an issue whereby the climber assumes further liability and decides to set their own levels of risk tolerance.
Taking this a step further, a tree climber can use certain belay devices to capture progress on ascent, and as a rappelling device on descent. Since belay devices are not necessarily designed for the purpose of tree climbing, performance varies when compared to other assisted braking descending devices using larger braking cams. Opinions do vary and with the exception of the GriGri, many major tree gear retailers sell a more robust and fuller featured variety of assisted braking descending devices, like the Petzl Rig or ID, including many with built-in lock-off and/or anti-panic functions.
Tree climbers have an assortment of options when it comes to rope grabs, auto-breaking-descenders, even multicenders, all of which can be used as lanyard adjusters. Multicenders like the Akimbo, Rope Runner, Unicender and Hitch Hiker are in fact ideal lanyard adjusters, but maybe not as lightweight, compact, inexpensive and practical for the majority of climbers. I’m on a personal quest for the perfect all around, lightweight, multicending lanyard adjuster designed specifically for static climbing ropes with 11 to 12.5 mm diameters.
The following video is several years old and new products and upgrades to these products are available, but the review discusses which types of devices are better suited and why belay devices are comparatively less effective when used in ways beyond their intended purpose.
I know a guy who mrts with a grigri. I just don't understand it enough because I mrt infrequently and only on a hitch climber setup or on my Akimbo, but I know he's a perfectly effective removal technician and a much faster than average climber.
I occassionally change over for descent onto two tails using an ATC, but it gets rarer as I started to incorporate mrt into my srt workflow about a year or two ago.
Just not sure where to go with this conversation since the options on the market are so much better than they were 1-6 years ago (thinking zigzag/unicender up through rope runner/bdb and then Akimbo)...
My intention is to help educate and draw more attention to the similarities and differences between rock and tree climbing gear. It also touches on the topic of non-conforming uses of gear, outside of a manufacturer's guidelines. Who knows, when it comes to better familiarizing climbers and would-be climbers on the use of belay devices, maybe this is a roundabout way to promote recreational/sport tree climbing, as well.
I learned how to rappel on an ATC when I first started climbing. My longest rappel ever was on an ATC... 275', out of a Sierra Redwood.
"Kinda dicey' is an interesting endorsement.
Would you elaborate on what you mean?
Sure. It is designed strictly for belaying. Proper usage involves two people and hands on the device at all times.
As a lanyard adjuster it could let you slip if it is bumped just right. However, I have found passing a bight through the biner and over the pilot will effectively lock it off. With a very little practice I can do this one-handed.
Anyhow, what I am doing is "off label" and not recommended.
Belay stuff like ATC for me in tree work - no thank you. No mention of Petzl Shunt. I've toyed in the past with using this in trees, esp. for safety line (11 mm) but always went back to just tree gear. Also Dave Stice makes a point in one Wesspur video that arb ropes are really static - not dymanic. Don't fall!. Hence the "work positioning" perspective v.s. "fall Protection". I wouldn't want to try climb SRT on a dynamic rope either cuz of the bounce compared to arb rope. Some is good but not too much, esp. in a tall tree. I don't think that I'm generally in favour of cross-over for most modern climbing gear into the arb world - who would want to climb on < 9 mm ropes anyway for work? I tell you some of us "old timers" look at the spaghetti that young guys go up an ice climb on and and shudder - no sir, I want some more textile holding my a$$ in the sky if bad things happen.
My 2 cents tonight from the cringing chicken. To each their own though.
A belay device can be used for descending in addition to a hitch or mechanical as the main attachment point. It’s a necessity for a hitch based SRT system on longer descents.
Tom with the sick burn! TTSSSSSSS
Yeah baybeeee! Love this place.
I'm a bit sensitive to the "minimalist" school of rec tree climbing. Minimalism and thriftiness are all admirable endeavors and qualities but... they never ever should be the foundation gear criteria for any activity involving life support on rope in a tree. Period. You've been warned ;-)
PS: Ask Tom Dunlap about the "whistle test" criteria for life support tree gear.
a
Not just in rec climbing either.
Years ago I was reading up on rope rescue systems and training. In more than one training discussion there was a reference to the 'whistle test'. What I found was that during a test of a new rescue system or for a certification a 'referee' would blow a whistle. The participants would go hands-off. The victim could not move more than a few inches from slack in the system. There was no allowance for setting a brake in the system. Further distances were a Fail.
Tree climber's muscle memory is built on 'let go/lock off'. Not like other roped climbers. In any stop the climber's system must be totally passive. In cars and baby seats we don't hold the buckle in one hand then clip it when we get in an accident. It's either on or off. No flipping a switch to turn on a safety.
There are belay/rapel devices that don't pass the whistle test. The result will be a fall if they're used. Not on my watch!
Just for reference I was once in a situation where I became dehydrated doing tree work. Probably other factors at play, nutrition the day before, maybe not enough sleep, pushing it too hard on multiple ascents that day, it could have been a mix of any number of variables. Both of my forearms cramped up at the same time, if you've experienced it you know what I'm talking about. I looked like a praying mantis, both forearms in a spasm upward, my hands useless claws. I couldn't believe it, my ground worker was laughing at me of course. The good news is I passed the whistle test.
Been there - forgot the olive oil for the ehs cable on a sappy tree brace/ cable job three years ago - twist and twist and twist thru the drilled holes in the trunks - hand/ arm cramps were worse than the screamin’ barfies topping out a -25 C ice climb. Really. Was on a hitchclimber pulley and couldn’t work the hitch or even do my usual munter on a biner on my leg loop thingy. So there I wuz 50 ft. up!
Am 100% a fan of whistle test stuff - on ice I come down on an ATC with a Shunt above it for that reason (and sometimes a munter or a ring below on my leg loop to strip ice and rope badness). No movie star rappels but not dead after thirty years of not acting my age either. Always we’ve stopped to think “what if” two or three steps ahead (course you still could just get clipped by a rock some bird kicks off, but oh well)! Great discussion.
Moss if we ever meet I’d like to buy you some sudz and we can yak rope splicey mystical folklore.
The joke about minimalist gear, is that the REAL minimum is a plain climbing rope. Which can absolutely pass whistle test when used properly, by itself in a rope on rope fiction hitch arrangement. The urge to use belayer/descender devices comes from other motivation besides weight saving or minimal set ups. I think it's more like, "I already have something that goes on a rope, I must be able to use it for any climbing."
