I reckon you have had a few climbs on your new kit Evo. Genuinely curious how your feeling about the Akimbo.
I love it. Not perfect, but that’s all me and break in. Much better than the bone for me, as I love to swap ropes and couldn’t get the bone dialed (none adjustable). Haven’t climbed too much on it, just 60’ or so on a doug, and then 7 very large apples. My upper cam got stuck which I think was my main issue dialing things in, it freed up with a drop of oil.
I weigh in just at 160# and have tried it on Yale Aztec in the field
The beam in my house I’ve tried:
Yale aztec 11.5
Sterling HTP 12.5
Velocity 11mm
Imori
Kernmaster 11mm
Sterling sucked! Couldn’t decend wife open and after just a few attempts I noticed milking. But I hate that rope anyway, I had the same issue on the wrench. I threw it in the rigging box, but figured I’d try it out. 11mm might be better, but the 12.5 left a bad taste in my mouth.
Velocity is the only rope I could get
any creep on, wide open. It flattened a bit as I turned up the friction, and got distracted. I think it also slipped max friction.
Imori actually worked damn well, with the widest range of settings.
Yale 11.7 on the work climbs was bomber for the first half of day one, and fought it the second half. Day 2 was double rope configuration on the apples. Low and slow right, after the big climb?! I fiddled with it all day, and finally got it just ok. But that is also when I discovered the upper cam was sticking.
Afterwards was all the testing on the assortment, and it runs great now that the cam is moving well again. Kinda sucks that it works best on the ropes I like the least (from what I own). This however gives me a baseline of what I like and what the akimbo likes. I need to look for a firm body, smooth jacket, with a good hand and little to no stretch in the biggest diameter I can find
recomendations wanted!
The break in time is real. Just from going up and down 12’ over and over half a dozen to a dozen times on each rope it left aluminum transfer on all the ropes.
