When is ART going to get on board with SRS?
To hit the question in your title. I'm sure they are working on something. The twinline can be used as a double srs canopy anchor, so I'm sure they're working on a multi cender too
I know it's a rope wrench type device, it just looks shorter than the singing tree rope wrench. I looked at a couple of the major tree gear sites and didn't see anything that looks quite like what is in the video. Maybe it's just the angle or maybe the t.v. makes the rope wrench look shorter... Maybe there is something in my water that I don't know about.
I have a spider Jack and considered buying a rope wrench to try with it even though some have said the combo is unreliable.
This is what you’re looking for RBJ
Have you used it in a tree yet? My understanding is that if the wrench can fall slack into neutral position and if not set or pushed up, when a decent begins it might stay un-set causing a free fall. I haven't used a rope wrench. I'm only about a month into srt use, mostly on a bulldog bone.
RBJ you are correct this setup is dangerous, and no I haven’t climbed a tree with it yet- just ascent and descent on rope. I will have to be super cautious because there is no spring in the system to set friction before pre weighting the line.
