SoftBankHawks
- Japan
ODSK and I made a video describing the Lov2 SRT device....check it out !
You can use the Lov 2 as a descender AND fall arrest, it has both certification but you will need two devices to run both options. Sorry that wasn’t so clear in the vid.Somewhat curious about the two rope option that was only lightly touched upon. So, if I heard correctly, in a sketchy tree I can run a bail out line to a bomber tie in and still work a normal canopy tie all off the same device?
Yes it can.Can this device be used as a sole life support and positioning device? Is anyone using it as such?
A little bit of Rope Wrench makes everything better!Strange pairing using the TAZ Lov2...
