the.schultz.effect
- currently in the bay area
first mistake: not building a rigging system that can handle the worst case scenario (a no run scenario, whether on purpose or accident) aka not doing the math!
when designing systems, rigging or climbing, especially negative rigging, they should be able to handle the maximum force that could possibly be generate by the piece! it should never hinge on the groundie being able to let it run. that's a poor rigging system.
it says the MBS of the rope is 9,390kg (20,700lbs), as soon as you add a running bowline you've reduced that by at least 40%, (something people always seem to forget
). 9,390kg - 40% = 5,634kg (12,420lbs) is what you're left with. you can very easily generate 10x's the weight of a piece when negative rigging, even more if you increase the fall distance like they did here, having the sling like 3ft below the notch! so basically a 563kg (1,242lbs) piece could break that rope. a quick look at a log weight chart and conservative guess on the dimensions of that lump will tell you it could easily weigh that much or more.
