Jimmycrackcorn
- Boston
Hey y'all.. so search results aren't kicking up much but i have a pretty basic question here that I've always wondered..
When is a cord considered a cord & rope considered rope?
I see lines like Reep Schnur considered a cord, I've also seen 25+ mm lines considered cord as well.. you look up these lines descriptions & they tell you they are good with heat, wear, this & that, commonly used for prussiks or hitches but they are the same size as some sport climbing ropes.. Then you have fancy names like tech cord all the way down to just regular "accessory cord"..
If these smaller lines are holding similar weight ratings as the bigger "climbing ropes", what's the difference & why would one not be able to use the "cord" as a climbing line? I mean i get the whole static vs dynamic thing but if they both have similar weight ratings & elongation ratings & both fall into favorable specs then why is one cord & one climbing rope?
Maybe this is a bad one because of its construction, but for just one example.. i just saw HRC spec'd out at 30 something mm.. if it's tough enough to be burnt up as a hitch cord, tough enough for shock load & it's big enough to comfortably climb on, why would one not want it to climb on it..
Another example would be a common 24 braid prussik cord vs rope..
Hope y'all can follow that.. i have a feeling there's a million ways that could be answered. I think I'm getting lost in the weeds here..
& Just a heads up.. although it may fall within the parameters of an answer, I'm not asking about what size cord to use with whatever rope..
Sent from my Pixel 2 XL using Tapatalk
