Here's my earlier post about pruning standards I would recommend
tree pruning primer
no live cuts on the main stem(s), or if the client insists only smaller cuts on the main stem(s), absolutely no live cuts over 4", even if you have to leave a stub, leave most epicormic shoots (sprouts), they are especially important to leave if they are near an existing wound, and if the client insists, then rather than remove all sprouts, just thin and shape, with the long term goal of having the sprouts develop into small limbs. It's also possible to leave a few stub on an initial heavy prune with the goal of letting those stub fill up with sprouts, rather than the trunk. Then 1-3 years later, the tree will have normalized its growth, the stubs that are loaded with sprouts can be removed with a clean target cut (or close to a target cut), without worrying about the tree filling up with new sprouts (this is especially helpful on ornamental fruit trees that require sever reduction in size). That is the best way to prevent an ornamental tree from filling up with sprouts after a hard prune.
and reduce mature hardwoods by making smaller cuts at the branch tips, especially on long, heavy over -extended laterals. If the limbs are over-extended heavily, or have structural defects they can be reduced as needed, up to 90% (leaving only a stub) on any individual limb, with the goal of minimizing overall loss of leaves, so that you can hit several lateral branches very hard, if needed, but then go light on the rest of the tree. In general leave the center of the tree and the uprights alone NO "CLEANING". Unless there are structural defects, let the tree grow up, just bring in the sides. If a tree has structural defects, it may be necessary to make large reduction cuts on the uprights, but in general try to avoid it, especially on certain species. When pruning to reduce stress on structural compromised trees, take the weight from the most leveraged place possible, which are the branch tips, especially the tops. Depending on the degree of the structural issue, and the risk of damage should the tree fail, you may need to go very heavy on the reduction cuts. Knowing how sensitive the species is is important, so you don't kill the tree. There are many species that can handle the European style 20' reductions, but many can't. So only take off as much as the tree can handle. No formula, just experience and instincts..
And NO ELEVATION except as absolutely required for human needs, The goal is to keep shade on the trunk and roots. So it is especially important to leave shade on the western and southwestern sides of the tree. if there are no other trees shading the trunk and roots, its very important to keep as much shade on the root and trunk as possible, with certain species being more sensitive than others.
And NO target cuts on anything big (roughly 3" or more), unless the target is perfectly clear. Always leave a stub long enough to be absolutely certain the branch protection zone is not violated. And if you know you'll be back to prune the tree again in the next few years, you can leave a sizable stub, 6 or 8 long, or even longer. If the stub sprouts, it can be pruned to train the new growth. if not, finish the cut once the limb is visibly dead and easily distinguished from the live collar on the trunk.
When making small cuts on the branch tips, 1" and under, target pruning really makes no difference. It's just quicker and easier to make the cuts some distance away from the branch union, and leave a small stub. this will have zero effect on the tree's health.
I always think it's better to bring back the big lateral limbs and leave the uprights growing unmolested. Each lateral is treated individually, with the amount of reduction to depend on multiple factors, including how far overextended it is, how big and heavy is the limb, how is it joined to the parent stem, how is the rest of the limb structurally, how sensitive the species is to pruning, what is the potential for property damage should the limb fail, and what is the clients tolerance for risk, when is the tree likely to get pruned again, and last but not least, how healthy and vital is the tree, meaning is taking a lot of weight and therefore leaves off going to significantly hurt the trees health.
