Frax
Dead trees. First off don't climb them if you have other options.
But we all need to climb one sooner or later. I've done my share of them, and I have a little list of things I test for. I know the big dawgs here can add a lot more. Let's start.
1. Know the species and know why the tree died if you can, and for how long the tree has been dead.
2. Check the root zone carefully, especially if you don't know why the tree died.
3. Pull test maybe.
4. On long dead trees, try to pull off limbs with throwline /rope from a distance. Me, being overly cautious imagine large limbs becoming dislodged and riding my rope onto my head. Hasn't happened yet, but it's the thing that bothers me most.
5. Always spike the tree, even if you don't have to. You get so much extra information from that.
6. If you have to rig, obviously as small as you can and find an expert roper. Take the smallest top by climbing as high as you dare on sound wood. I add one or more vertical redirects above my main tie which is cinched around the strongest point I can find at height so I can get up there safely. If something breaks, at least I'll only fall a few feet. That's only to cover the unseen hazard. If you think the top is very possibly to weak to hold you, you should abandon the mission.
What else do you guys do?
The images are from last week's pine. Just the limbs and small top taken off. The stem was felled.
3. Pull test maybe.
